hi everybody
im intersting to know that has alcatel oxe any solution for call routing at onhook (not offhook)? my mean that when i hangup the call , it transfer to another number.
Re: call routing at onhook
Not exist in Alcatel. Onhook=release.
You can press f.e. programmed key (select destination) and onhook (if transfer by no answer supported).
Strange requirement. After any calls - try to transfer call to another destination.
I had this request too, in my case was to transfer the call to a survey for example...
Yeah... Very popular demand from call-center's staff. Possible only with new OTCS.cavagnaro wrote:I had this request too, in my case was to transfer the call to a survey for example...
Really? Can you pls point out the exact feature?
When I asked ALU for "call survey" feature they just quoted OTCS and said that a script needed to be written to do this .
We have done this a couple of times, using back to back trunks that play a incoming greeting guide or AA, but you need to press a button to start the process on the Contact Center phone!
