2 Problems full time
energydat
Post by energydat »
Hello Everybody...
can me someone give help with this 3 Messages?
Thank you.
07/02/17 11:20:10 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:21:09 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:21:49 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:24:27 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:40:19 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:42:57 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 11:50:15 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:03:09 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:09:48 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:11:45 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:15:04 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:33:32 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 12:58:56 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 13:25:57 001001M|006/00/0/001|=3:1305=MCDU in distri table OPE 1, column Day , line 4 incorrect or missing
07/02/17 13:25:57 001001M|006/19/0/000|=3:1305=MCDU in distri table OPE 1, column Day , line 4 incorrect or missing
07/02/17 13:26:27 001001M|006/19/0/000|=3:1305=MCDU in distri table OPE 1, column Day , line 4 incorrect or missing
07/02/17 13:30:41 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 13:33:20 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 13:46:31 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 13:52:48 001001M|004/00/0/054|=3:1306=MCDU in distri table OPE gpe 3, column Day , line 4 incorrect or missing
07/02/17 13:52:50 001001M|006/00/0/001|=3:1306=MCDU in distri table OPE gpe 3, column Day , line 4 incorrect or missing
07/02/17 13:53:00 001001M|006/00/0/001|=3:1306x002=MCDU in distri table OPE gpe 3, column Day , line 4 incorrect or missing
07/02/17 13:53:00 001001M|006/00/0/000|=3:1306=MCDU in distri table OPE gpe 3, column Day , line 4 incorrect or missing
07/02/17 13:53:30 001001M|006/00/0/000|=3:1306x002=MCDU in distri table OPE gpe 3, column Day , line 4 incorrect or missing
07/02/17 14:07:00 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 14:16:01 001001M|---/--/-/---|=3:1405=ABCA rout src 0 .1.-1
07/02/17 14:45:26 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 15:00:10 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
07/02/17 15:07:04 001001M|001/04/-/---|=4:3580=remove TEI: mod ??? UNSUCCESSFULL_RETRANS_OF_SABME (0) realy:0 info:5
Re: 2 Problems full time
Use command "incinfo" for incident explanation.
1305 and 1306 - CDT of operator/ operator group - not correctly filled in. PBX not know route destination for calls.
3580 - some problem with PRA2 board.
Return to “ON SITE TROUBLES”
