AP 205H POE out disable
Also known as OmniAccess Instant AP
mustafa.ahmad
Post by mustafa.ahmad »
We have installed the AP205H with controller 4450. we have to connected IP phone behind AP but there is no power. AP is connected behind the 6450-P48.
Please advise how to activate POE port to connect IP phone behind AP205H.
Re: AP 205H POE out disable
inside the AP is a "normal" switch without POE. Only RAP3WNP (with own powersource) delivered POE.
You need powersupply for your phone or an injector.
mustafa.ahmad
I am using AP305H
it has one in built POE port, mentioned in the docs
mustafa.ahmad
sorry it s 205 H
check in your OAW if poe is enabled.
wireless lan - your ap group > AP > Ethernet interface 1 port configuration > Ethernet interface link > POE
You are realy sure that you don't need an external powersupply at the AP? I haven't seen this AP until now.
devnull
Post by devnull »
Also: From Datasheet the AP205 provides 5W maximum, so check that your phone does not use more power
(have not had such AP yet)
Return to “OmniAccess Wireless Access Points”
