Call Back of speed dial is not going to Avaya instead going to OXE
HUSSAINQCS
Post by HUSSAINQCS »
We have similar numbering plan in OXE and Avaya side
In OXE side :
Room user(7215)
In Avaya side:
Admin user(7215)
When i received a missed call from Avaya side 7215 i was trying to call back the same number from the call logs but call is going to OXE room user
i configured the Avaya Extension Number as speed dial prefix
oldboy
Re: Call Back of speed dial is not going to Avaya instead going to OXE
Post by oldboy »
how are you calling the same number from a Abb number??
HUSSAINQCS
i was just dailling the received missed calls
HUSSAINQCS
speed dial prefix: #7512
call no : #757512
#7 is the routing no
tgn
Post by tgn »
HUSSAINQCS wrote: 21 May 2017 15:56 call no : #757512
this makes no sense... when #7 is the routing number and 7512 is the extension number in avaya... wth is 5 between them?
but anyway... the avaya pbx must send you the complete number for callback...
regards...
HUSSAINQCS
I was using call number #17512 sorry
HUSSAINQCS
#1 ARS prof.Trg seize
For call back - you need to have good calling number, not just 7512 (in this case you will have call back to local number):
- f.e. in External callback translation - create string - Basic number 7, delete 0, add# - in this case for not answered call from Avaya 7512 OXE will record number #7512 for callback.
HUSSAINQCS
No i tried still going to OXE side not to avaya side
HUSSAINQCS
And this is happening for incoming missed calls from Avaya side
Return to “Speed Dialing”
