What is this? Deflector OXE
bonilleta
Post by bonilleta »
I'm doing a migration for OXE version 12.1 and the Actis quote adicional component that i don't know what is this. Can u help me please?
I don't know what is "deflector" for one closet:
Add image: http://i.imgur.com/7xDZmOI.png
Thank You!
tgn
Re: What is this? Deflector OXE
Post by tgn »
the deflector is a piece of metal sheet. it leads the airflow from the upper side fans of a shelf to the back of the rack so that the warm air will not go through other shelfs above.
regards...
