Eva tool not accessible
HUSSAINQCS
Post by HUSSAINQCS »
I was using appliance server OXE release 11.1
I was not able to access the Eva_tool and its showing error
file /DHS3data/mao/eva.cfg not found
when I give the command
Also I m getting the incidents
02/08/17 09:29:34 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.16 Module 0x 0. 0 Line 0x 0.54 in the voicemail Appliance server
Re: Eva tool not accessible
Which Voice Mail do you have?
HUSSAINQCS
4645
You have answer - file /DHS3data/mao/eva.cfg not found.
4645 - installed, works? Before - Eva tool works?
HUSSAINQCS
Yes Mr.vad it was happened when try to delete mailbox for users through Evatool now it was automatically resolved what could be the root cause ?
Return to “Voicemail (46x5)”
