Swap from PRI External Line to Analog External Line
deliad
Post by deliad »
I have alcatel 4400 pbx with PRI for external Lines configured on BPRA card
I want to Swap the PRI setup with an analog lines to make calls from analog lines thru the 4400 via NDDI Card that is installed
the 4400 will pickup the most first and free line available
i have access to the telnet with mtcl user and i know the mgr console,
this 4400 has been used with analog lines for specific prefix before and it was disabled when we switched to PRI
now i want use 6 analog lines instead of the PRI for external calls
can someone tell me what are the steps in detail that needs to be done?
deliad
Re: Swap from PRI External Line to Analog External Line
Post by deliad »
i have NDDI Board installed
Add those trunks to the trunk group.
Download system documentation, you will find everything you need in the
