Dect 8232 - Inverted display issue
Nophelet
Post by Nophelet »
How can I turn display for normal display?
All options work. Nothing from a service menu or a test menu does not solve a issue.
Any ideas please.
thanks
Osh
Re: Dect 8232 - Inverted display issue
Post by Osh »
I have the same problem, and the exchange of the screen didn't fix it.
Return to “DECT”
