A user with hearing iaaues
Flava
Post by Flava »
Hi All
We have a user who is struggling to hear people on the phone. They work in an open plan office. They do not wear hearing aids and are refusing to go for a hearing test.
Our system is an Omnivista 4400 and we use IP4028 and IP4018 handsets. We have other users who have hearing aids who use a streamer to blue tooth their hearing aids to an IP4068, we can't do that in this case.
Any help would be gratefully received.
Andy
Re: A user with hearing iaaues
Try to adjust audio level in handset (during conversation, with "+", "-" keys on telephone set). (Specific telephone services, item "Adjust audio gain" must be checked)
Flava
Post by Flava »
Hi vad
Thank you for the reply. Unfortunately we have tried that.
sadim
Post by sadim »
Try to increase the level 5 on the "Handset Reception Audio Path" under Alcatel-Lucent 8&9 Series/8&9 Series Sets Audio Parameters. Then make the test setting the audio level on the phone set to 5
sadim
Post by sadim »
Also there are some handset amplifiers on the market. For instance Plantronics HA-40 and Clarity HA-40. But never test. So no warranty
Either increase the system audio level like Sadim said above (you might have to reset the set itself, or the whole system, i don t remember).
Or check on the AAPP web site, they have plenty of solution for hearing impaired people.
Return to “MAIN”
