OpenTouch RestApi: 403 Foridden AlcChameleonException.BAD_FRAMEWORK_SESSION_IDENTIFIER
Download the API here: http://api.aapp.al-enterprise.com
michael_2017
Post by michael_2017 »
Hallo,
i had OpenTouch(OpenTouch Multimedia Services 2.2) server. After login over /api/rest/authenticate?version=1.0 get an cooky with session key.
The problem if call than /api/rest/1.0/sessions or an other url from rest api became an http status 403.
If i want to read the session infomation from server get http status 403 and message:
{"httpStatus":"FORBIDDEN","code":1001,"helpMessage":"No valid session found for the given identifier. Please logout and login with correct credentials.","type":"INVALID_SESSION","innerMessage":"AlcChameleonException.BAD_FRAMEWORK_SESSION_IDENTIFIER No framework session in API with this ID : 16.....313","canRetry":true}
is this an problem from server config or problem from my request?
Re: OpenTouch RestApi: 403 Foridden AlcChameleonException.BAD_FRAMEWORK_SESSION_IDENTIFIER
Need debug. What cookie do you get, what id do you send to the URL ? Your request is probably not setup correctly.
michael_2017
i had 2 cookies
AlCuserId for path /
JSESSIONID for path /api/
my request after login over /api/rest/authenticate?version=1.0
Is the session timer expired maybe ?
What is it setup at ?
Did you also try the REST API CLIENT ?
michael_2017
if i use rest Api client from acatel i get an error with number 253.
08:47:09.997 [JavaFX Application Thread] DEBUG a.r.t.ws.gui.AuthenticateController - Issue : 253
javax.ws.rs.ProcessingException: 253
at org.glassfish.jersey.client.ClientRuntime.invoke(ClientRuntime.java:234)
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:655)
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:652)
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
at org.glassfish.jersey.internal.Errors.process(Errors.java:228)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:423)
at org.glassfish.jersey.client.JerseyInvocation.invoke(JerseyInvocation.java:652)
at org.glassfish.jersey.client.JerseyInvocation$Builder.method(JerseyInvocation.java:387)
at org.glassfish.jersey.client.JerseyInvocation$Builder.get(JerseyInvocation.java:291)
at alcatel_lucent.rest.tools.ws.authent.Authentication.authenticate(Authentication.java:86)
at alcatel_lucent.rest.tools.ws.gui.AuthenticateController.actionLaunch(AuthenticateController.java:205)
at alcatel_lucent.rest.tools.ws.gui.AuthenticateController.authenticate(AuthenticateController.java:108)
on server is kerberos authenticate activate.
I'm sorry I do not have an open touch here. I guess open a ticket with ALE ... and let us know ..
Just curious - Have you tried with a POST instead of a GET ?
PeterPinnau
Post by PeterPinnau »
michael_2017 wrote: 18 Sep 2017 05:30 If i want to read the session infomation from server get http status 403 and message:
I received the same problem and finally found my mistake. Maybe someone is interested.
After you authenticated via basic auth and got the AclUserId token you MUST open a session. Therefor a HTTP POST to /api/rest/1.0/sessions must be send. An identifier for your application has to be passed in the POST data as JSON:
"applicationName": "MyApplication"
The respone gives you a list of features available:
"admin": false,
"timeToLive": 1800,
"publicBaseUrl": "https://otms.yourdomain.local:443/api/rest/1.0",
"privateBaseUrl": "https://otms.yourdomain.local:443/api/rest/1.0",
"services": [
"serviceName": "Logins",
"serviceVersion": "1.0",
"relativeUrl": "/logins"
"serviceName": "Users",
"relativeUrl": "/users"
"serviceName": "BasicTelephony",
"relativeUrl": "/telephony/basicCall"
"serviceName": "Storage",
"relativeUrl": "/storage"
"serviceName": "Performance",
"relativeUrl": "Performance"
"serviceName": "Privacy",
"relativeUrl": "/privacy"
"serviceName": "SystemInfo",
"relativeUrl": "/systems"
"serviceName": "Message",
"relativeUrl": "/messages"
"capabilities": [
"BASIC_TELEPHONY"
Note that you MUST send the POST request to open the session immediatly after the basic auth. If you do any other request like "GET /sessions" you will receive AlcChameleonException.BAD_FRAMEWORK_SESSION_IDENTIFIER.
You can use "Postman" to connect to the service a play around with it. Postman is a very useful tool when working with REST services. You must use the recent version from https://www.getpostman.com since former versions do not support cookies.
If my current project has some time left I probably will make a short video howto connect to the Alcatel REST service via Postman and dial a number.
Return to “Web Services”
