No calls between two MG
enio.eltz
Post by enio.eltz »
Hello
Thanks for any answer in advance.
System is OXE R12.0_m1.403.15.h. It was migrated from R9.1_i1.605.40. CPU is CS-2.
After five days running ok, I am facing a situation where two MG can't call to each other. System has Cr2 with two expansions (Cr 3 and Cr4) in local area and a remote MG Cr5. I can't call from an extension at Cr2/3/4 to Cr5. The other way too.
Cr2 is a GD and Cr5 is a GD-3.
I have already restarted both GD boards and all the system, but no success.
Checking the system, I realized an information with compvisu command.
compvisu 2 0 is showing an information in Busy. It shows Busy: OFF, no TG!!
| C O M P R E S S O R S T A T E Coupler type : GD, (2-0) MADA3 |
| Coupler state : IN SERVICE |
| - compvisu - Busy : OFF, no TG !! |
| | TS : 4 5 6 7 8 9 10 11 12 13 14 15 17 |
|PCM| Neqt : 1463 |
| 0 | Comp : CI . . . . . . . . . . . . |
| | TS : 18 19 20 21 22 23 24 25 26 27 28 |
|PCM| Neqt : |
| 0 | Comp : . . . . . . . . . . . |
| Max Nb Compr Allowed SIMULTANEOUSLY : 24 |
| Compr State: X = unusable, . = Free, OS = Out Of Service |
| IP Device : CI = Local IP Phone, CR = Local Remote |
| RTP Direct : CG = Comp used:Flux RTP on GW, FI = Comp Free:Flux RTP on IPP |
| Fax Over IP: TF = T38 Fax |
| Transparency over IP : M = Modem, D = Data |
compvisu 5 0 is showing a different information in Busy. It shows Busy: OFF
| C O M P R E S S O R S T A T E Coupler type : GD3, (5-0) 0ARMAD |
| - compvisu - Busy : OFF |
| | TS : 1 2 3 4 5 6 7 8 9 10 11 12 13 |
|PCM| Neqt : |
| 0 | Comp : . . . . . . . . . . . . . |
| | TS : 14 15 17 18 19 20 21 22 23 24 25 26 27 |
|PCM| Neqt : |
| | TS : 28 29 30 31 |
|PCM| Neqt : |
| 0 | Comp : . . . . |
| Max Nb Compr Allowed SIMULTANEOUSLY : 22 |
I really don't know why.
Did anybody see anything like this?
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
enio.eltz
Re: No calls between two MG
Post by enio.eltz »
I have found this:
http://www.alcatelunleashed.com/viewtopic.php?t=13974
Trying to check some configuration.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
sadim
Post by sadim »
enio.eltz wrote:Hi
I have found this:
Check IP domains.
Is the IP address of GD boards configured on any IP domain
Bregards
Enviado do meu WAS-LX1A através de Tapatalk
enio.eltz
Post by enio.eltz »
Hi sadim
Yes, they are.
GD of the Cr2 is 10.51.151.2. This IP address is configured on IP domain 0.
GD-3 of the Cr5 is 192.168.1.241. This IP address is configured on IP domain 1.
Configuration of IP domain 0:
┌─Review/Modify: IP domain──────────────────────────────────────────────────────────────┐
                                       │             Node Number (reserved) : 1                                                │
                                       │                Instance (reserved) : 1                                                │
                                       │                   IP Domain Number : 0                                                │
                                       │                     IP Domain Name : ABDO_NH                                          │
                                       │                            Country + Default                                          │
                                       │      Intra-domain Coding Algorithm + With Compression                                 │
                                       │      Extra-domain Coding Algorithm + With Compression                                 │
                                       │ FAX/MODEM Intra domain call transp + NO                                               │
                                       │ FAX/MODEM Extra domain call transp + NO                                               │
                                       │       G722 allowed in Intra-domain + NO                                               │
                                       │       G722 allowed in Extra-domain + NO                                               │
                                       │    Accept conf. circ. of other dom + YES                                              │
                                       │   Provide conf. circ. to other dom + YES                                              │
                                       │              Tandem Primary Domain : -1                                               │
                                       │        Domain Max Voice Connection : -1                                               │
                                       │              IP Quality of service : 0                                                │
                                       │                     Contact Number : ------------------------------                   │
                                       │                  Backup IP address : -----------------------------------------------  │
                                       │                     Trunk Group ID : -1                                               │
                                       │    IP recording quality of service : 0                                                │
                                       │                     Time Zone Name + System Default                                   │
                                       │                 Calling Identifier : ------------------------------                   │
                                       │     Supplement. Calling Identifier : ------------------------------                   │
                                       │             SIP Survivability Mode + NO                                               │
Configuration of IP domain 1:
                                       │                   IP Domain Number : 1                                                │
                                       │                     IP Domain Name : ABDO_FLPA                                        │
                                       │                  Backup IP address : 192.168.1.240                                    │
                                       │           Voice Services Broadcast + YES                                              │
                                       │                     IP Domain Type + Not IP                                           │
Thank you very much.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
config all - show free channel for inter shelf communication?
incvisu - do you have some incident during calls?
tgn
Post by tgn »
"ip domain type" must be "ip" in ip domain 1.
regards...
sadim
Post by sadim »
Like i suspect and like tgn says, ip domain must be ip type.
BRegards
enio.eltz
Post by enio.eltz »
I changed this configuration last night, local time. But I can't run test. Test will be done this morning.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
enio.eltz
Post by enio.eltz »
I ran tests and calls between MG are OK.
So, I understand the solution that tgn and sadim proposed was the cause.
But for information, it worked 6 days without "ip domain type" as "not IP". But no problem.
Thank you guys for the whole help in this case.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
alexeik
Post by alexeik »
some time ago i had the situation that the ip domain was ip, but chenged to not ip without any interference. I changed it back and all was fine. Version was 11.0.1...
Return to “Media Gateway”
