I'm beginner and I need your help about accounting using OmniVetsa 4760i for a PBX OXE with a print screen if possible.
thanks in advance.
Procedure to configure Accounting in PBX OXE using OmniVesta 4760i
Re: Procedure to configure Accounting in PBX OXE using OmniVesta 4760i
4760i is only a light version of 4760 just for Configuration. If you want other features you need full 4760 and licenses.
If you have 4760 then search the forum or read documentation that is available
seddik
Thank you very much cavagnaro ,this is why I didn't found the file TAX**.DAT in user4/accounting.so if I install 4760 this file will be created automatically?is that right?
That is a license in your PBX, 4760 is actually only a client that process that file.
Do you have that license? Accounting? Have you enabled it?
Check system documentation on how to do this so you get a better idea.
Sys docs are uploaded here, just search
