How to config setup password GD2 card
Luan-Duong
Post by Luan-Duong »
Hi Team Support ,
I need reinstaller Password GD2 card because I can not login GD2 card .
I want reset default password on GD2 card , Help me .
Ngoc Luan
oldboy
Re: How to config setup password GD2 card
Post by oldboy »
didnt think you could change the password on a GD card or if you would want to ever change it!
Luan-Duong
Thank you Pro.
You cannot open connection with "admin" login via console port (CONFIG)?
or via telnet?
Return to “Media Gateway”
