OXO Local Call Metering API
acasella
Post by acasella »
Hello
I've to read local call records from an Alcatel OXO PBX (Release > 9). I know that there is function called Local call metering application (LCMA) which connects to the PBX and saves records for local calls into an XML file on a PC.
I want to develop an external application to read local call records connecting to the PBX directly, whitout reading the XML saved by LCMA.
Is there an API on the Alcatel OXO PBX (like the SOAP Call Accounting Web Service used to read incoming/outgoing call records) to do this?
Re: OXO Local Call Metering API
Start here: https://applicationpartner.alcatel-lucent.com
Register, read check for available APIs on OXO.
acasella
Post by acasella »
tot3nkopf wrote: 22 Jan 2018 06:22 Start here: https://applicationpartner.alcatel-lucent.com
Thanks. I've already registred to the AAPP program, but i haven't found an API to read internal calls.
Any other suggestions?
Return to “Hotel mode”
