configuring ntp services
madidi123456789malo
Post by madidi123456789malo »
Hi Everyone,
I am configuring NTP in my 6850 Alcatel switch ,Switch is not synchronised with NTP server
NTP configuration as below , anyone suggest how to resolve this issue .
devnull
Re: configuring ntp services
Post by devnull »
try to wait some time, but if you want to get time from a server that is NOT synced against some Master clock (from your output visible as it is stratum 16) it will not work.
From Manual:
"Note
The NTP protocol discards the NTP servers that are unsynchronized.
To disable an NTP client from invoking tests for NTP server synchronization, enter the
ntp server unsynchronized command, as shown:
-> ntp server unsynchronized
Disabling peer synchronization tests allows the NTP client to synchronize with either an NTP peer that is not synchronized with an atomic clock or a network of NTP servers that will finally synchronize with an atomic clock."
So
should help
