lost root and swinst password
Did you say hacking ?
anisbou
Post by anisbou »
hi
i lost my root and swinst password but i have access to mtcl login,my customer want to upgrade the system from R9.0 to R12.0.The probleme is how to take the backup of the system
Turlupin
Re: lost root and swinst password
Post by Turlupin »
You can grab the backup files under /usr4/BACKUP/DAY with your ftp client. The mtcl can access this directory.
Turlupin
Sorry for my english .... :)
tgn
Post by tgn »
Lost the mtcl password in R12.
https://r.tapatalk.com/shareLink?share_ ... are_type=t
regards...
oldboy
Post by oldboy »
Turlupin wrote: 26 Apr 2018 12:10 Hi,
Turlupin
You cannot use that Backup for an Upgrade... the DB needs to be rebuilt then an immediate Backup taken, the DAY backup is used to rebuilt the system on the same release already installed.
Return to “System Hacking”
