Break in
Alex_Brazil
Break in
Post by Alex_Brazil »
Hi!
I`m trying to do a Break in. I've already did everething is in the expert documentation but did not work. The call go to operator, and then I can transfer to remote site. It shows that the route is ok and something on numbering plans is not working, I think.
Maybe should be a BUG.
There are someone that can help me?
ps. release 5 (R510/018)
Re: Break in
Joining of the external lines?
steve
Re: Break in
Post by steve »
Transfer ext/ext in the SistemMisc/Feature Design/part2 ?
Alex_Brazil
Re: Break in
Yes! Both. Thank's
Return to “Configuration”
