SAS-R 7210 switching on ports in LAG hit the traffic
ahmads143
Post by ahmads143 »
Hi Team,
Need your help..While switching the ports (which is in LAG 1/1/19 & 1/1/21) from worker port(1/1/19) to slave port(1/1/21)
During switching traffic from Master to slave port , Traffic affected for almost 30-40 seconds
While Switching from Slave to Master, No traffic affected or fluctuate during interval
Can you please suggest is this normal of traffic hit of 30-40 sec, while switching the traffic if 1/1/19 will be down ?
but no traffic effect when reverting ...
Below is my config in my SAS router
configure lag 11
description "XXXXXXXXXXXXXXXXXXX"
mode access
encap-type dot1q
port 1/1/21 priority 200
port 1/1/19 priority 100
selection-criteria best-port
standby-signaling power-off
no shutdown
exit
card
sys-res-profile 2
card-type imm-sas-b-11csfp
mda 1
configure port 1/1/21
description "_XXXXXXXXXXXXXXXXXXXXXXXX"
no shutdown
ethernet
mode access
access
egress
qos 10
exit
exit
encap-type dot1q
no autonegotiate
exit
exit
configure port 1/1/19
no shutdown
ethernet
mode access
access
egress
qos 10
exit
exit
encap-type dot1q
no autonegotiate
exit
exit
thekotaksampah
Re: SAS-R 7210 switching on ports in LAG hit the traffic
Post by thekotaksampah »
can you change "standby-signaling power-off" to standby on and make traffic avoid this port?
Technical Blog: ngoprek.achyarnurandi.id
ahmads143
Post by ahmads143 »
I did change the lag config for " no standby signal "( no command standby signal on ) and it went smooth and was no traffic hit at the time of switch and also at the time of reverting..many thanks for the suggestion
One quick query
As both ports will be up (after no standby signal command)..how will I come to know traffic is reverted back or not..? If am not wrong here priority will come into picture ?
Like priority 100 will work ?
ahmads143
Post by ahmads143 »
Working all fine on standby power on
Many thanks
Return to “7210 SAS”
