I trying to solve this issue we have, a 8028s set monitored by a Voice Logger trying to do outgoing using E1 ISDN call always disconnected if not answered within two rings. But if the calls is answered within two rings and connected calls were not drop.
Another Scenario:
There are also 8028s sets but not monitored by a Voice logger works fine. Meaning if they use the same trunk group calls not drop even it reaches 6-8 rings.
I used ARS for the trunk seizure.
Anyone had the same experience?
Thank you,
Nel
Call drops or disconnect within two rings
- jonnel_ponesto
Re: Call drops or disconnect within two rings
Check with t3 trace:
- for disconnected calls - disconnect from your PBX or from provider
- compare t3 trace for both sets (for the same external number).
- jonnel_ponesto
Thank you Vad, I compare the traces I saw disconnect message from OXE side.
Below is the disconnection E1 ISDN Trace.
| (074017:000009:04501) 4501: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 56 desti: 0 source: 15 cryst: 2 cpl: 11 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 03 43
| IE:[18] CHANNEL (l=3) a9 83 9e -> T2 : B channel 30 exclusive
| IE:[6c] CALLING_NUMBER (l=11) -> 00 81 Num : 028575661
| IE:[70] CALLED_NUMBER (l=8) -> 80 Num : 8579701
| IE:[7d] HLC (l=2) 91 81
| [a1] Sending complete
| (074119:000039:04501) 4501: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 2 cpl: 11 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 03 43
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (074122:000041:04501) 4501: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 11 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 03 43
after sending complete you don't receive any message ?! a call proc message for exemple ?!
- jonnel_ponesto
actually there is call proc message I didn't include in the trace I pasted. And extension can hear ringing before the disconnection.
Post full logs...
- jonnel_ponesto
Hi Cavagnaro,
I capture a new trace, please see details below. extension is 5669 calling 9825890.
| IE:[6c] CALLING_NUMBER (l=11) -> 00 81 Num : 028575669
| IE:[70] CALLED_NUMBER (l=8) -> 80 Num : 9825890
Thank you.
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(316778:000001:14229) MTRACER host (10.203.0.3, mbtc_hyatt_a), version: R12.0-m1.403-21-a-ph-c0
(316778:000001:14229) MTRACER num: 041, time: 2018/09/11 16:36:04, loss: 0%
| (316796:000002:04727) Concatenated-Physical-Event :
| long: 80 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 37
| SENDING COMPLETE
| IE:[18] CHANNEL (l=1) a3 -> T2 : Any B channel
| IE:[6c] CALLING_NUMBER (l=6) -> 81 Num : a9999
| IE:[70] CALLED_NUMBER (l=6) -> 81 Num : a9001
| [97] Locking shift. codeset : 7
| IE:[06] EI_IP_PAYLOADS (l=2) : (COMP/ECE/VAD) -> G729/0/0 G729/0/1
| IE:[0a] EI_RTP_INFO (l=30)
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=0 rqm=0
| -> Transm_Bande=1 detection_Q23=1 dtmf_payload=96
| -> Port RTP = 32624, IPv4 : 172. 16. 97. 20.
| -> Port RTCP SR = 32625, IPv4 : 172. 16. 97. 20.
| -> Port RTCP RR = 32625, IPv4 : 172. 16. 97. 20.
| -> Port Fax = 0, IPv4 : 0. 0. 0. 0.
| (316796:000004:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 29 desti: 0 source: 15 cryst: 2 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 37
| [9f] Non-locking shift. codeset : 7
| IE:[07] EI_IP_QOS (l=3) b8 a0 00
| IE:[18] CHANNEL (l=3) a8 83 83 -> T2 : No B channel
| (316796:000005:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 55 desti: 0 source: 15 cryst: 2 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 37
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 1 Vad 0
| -> Port RTP = 32540, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32541, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32541, IPv4 : 10. 203. 0. 7.
| (316796:000007:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 37
| (316797:000009:04727) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 37
| (316798:000010:04727) Concatenated-Physical-Event :
| IE:[08] CAUSE (l=2) 81 e5 -> [e5] MESSAGE NOT COMPATIBLE WITH CALL STATE
| (316798:000011:04727) Concatenated-Physical-Event :
| (316805:000012:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 6e
| SENDING COMPLETE
| -> Port RTP = 32680, IPv4 : 172. 16. 101. 236.
| -> Port RTCP SR = 32681, IPv4 : 172. 16. 101. 236.
| -> Port RTCP RR = 32681, IPv4 : 172. 16. 101. 236.
| (316805:000014:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 6e
| (316805:000015:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 6e
| -> Port RTP = 32548, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32549, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32549, IPv4 : 10. 203. 0. 7.
| (316805:000017:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 6e
| (316805:000019:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 6e
| (316806:000021:04727) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 6e
| (316808:000022:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 10
| (316808:000023:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 10
| (316813:000024:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 6e
| (316813:000025:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 6e
| (316816:000026:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 df
| IE:[18] CHANNEL (l=3) a9 83 89 -> T2 : B channel 9 exclusive
| (316817:000028:04727) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 11 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 df
| (316822:000029:04727) Concatenated-Physical-Event :
| long: 81 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 23
| SENDING COMPLETE
| IE:[6c] CALLING_NUMBER (l=7) -> 81 Num : a31880
| -> Port RTP = 32514, IPv4 : 10. 200. 28. 231.
| -> Port RTCP SR = 32515, IPv4 : 10. 200. 28. 231.
| -> Port RTCP RR = 32515, IPv4 : 10. 200. 28. 231.
| (316822:000031:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 23
| (316822:000032:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 23
| -> Port RTP = 32556, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32557, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32557, IPv4 : 10. 203. 0. 7.
| (316822:000034:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 23
| (316822:000036:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 23
| (316823:000038:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 23
| (316830:000039:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 106 desti: 0 source: 15 cryst: 2 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 30 9a
| [a1] EI_IP_TYPE_NODE
| IE:[05] EI_IP_INFOS (l=9) -> G729 Ece 1 Vad 0 Profil 2, IPv4 :172.16.97.13.
| IE:[06] EI_IP_PAYLOADS (l=1) -> G723 Ece 1 Vad 0
| -> stop_packet=0 stop_rtp=0 h323=0 wc=0 rf=0 udp=1 rqm=0
| -> Port RTP = 32514, IPv4 : 10. 203. 0. 14.
| -> Port RTCP SR = 32515, IPv4 : 10. 203. 0. 14.
| -> Port RTCP RR = 32515, IPv4 : 10. 203. 0. 14.
| IE:[18] CHANNEL (l=3) a8 83 88 -> T2 : No B channel
| IE:[6c] CALLING_NUMBER (l=6) -> 81 Num : a9001
| IE:[70] CALLED_NUMBER (l=6) -> 81 Num : a8000
| (316831:000041:04727) Concatenated-Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : b0 9a
| IE:[18] CHANNEL (l=1) a8 -> T2 : No B channel
| (316834:000042:04727) Concatenated-Physical-Event :
| long: 54 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : b0 9a
| IE:[06] EI_IP_PAYLOADS (l=1) -> G729 Ece 0 Vad 0
| -> Port RTP = 32840, IPv4 : 172. 16. 97. 8.
| -> Port RTCP SR = 32841, IPv4 : 172. 16. 97. 8.
| -> Port RTCP RR = 32841, IPv4 : 172. 16. 97. 8.
| (316834:000043:04727) Concatenated-Physical-Event :
| long: 26 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CONNECT (07) Call ref : b0 9a
| IE:[0a] EI_RTP_INFO (l=2)
| (316834:000044:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 15 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT ACK (0f) Call ref : 30 9a
| (316834:000045:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 30 9a
| (316846:000047:04727) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 11 us: 0 term: 0 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 df
| IE:[1e] PROGRESS_ID (l=2) 82 88
| (316846:000048:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| -> Port RTP = 32514, IPv4 : 10. 203. 1. 213.
| -> Port RTCP SR = 32515, IPv4 : 10. 203. 1. 213.
| -> Port RTCP RR = 32515, IPv4 : 10. 203. 1. 213.
| (316848:000050:04727) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : FACILITY [62] Call ref : 00 23
| (316853:000051:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 81
| SENDING COMPLETE
| -> Port RTP = 32684, IPv4 : 172. 16. 101. 236.
| -> Port RTCP SR = 32685, IPv4 : 172. 16. 101. 236.
| -> Port RTCP RR = 32685, IPv4 : 172. 16. 101. 236.
| (316853:000053:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 81
| IE:[18] CHANNEL (l=3) a8 83 94 -> T2 : No B channel
| (316853:000054:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 81
| -> Port RTP = 32564, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32565, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32565, IPv4 : 10. 203. 0. 7.
| (316853:000056:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 81
| (316853:000058:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 81
| (316854:000060:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 81
| (316874:000061:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 5d
| -> Port RTP = 32624, IPv4 : 10. 203. 0. 6.
| -> Port RTCP SR = 32625, IPv4 : 10. 203. 0. 6.
| -> Port RTCP RR = 32625, IPv4 : 10. 203. 0. 6.
| (316875:000063:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 00 5d
| (316875:000064:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 80 5d
| (316917:000065:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 04 df
| (316920:000066:04727) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 11 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 84 df
| (316920:000067:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 04 df
| (316921:000068:04727) Concatenated-Physical-Event :
| long: 21 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : NOTIFY [6e] Call ref : b1 50
| IE:[27] NOTIF_INDI (l=1) 80 : User suspended
| (316941:000069:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 5b
| SENDING COMPLETE
| -> Port RTP = 32748, IPv4 : 172. 16. 97. 8.
| -> Port RTCP SR = 32749, IPv4 : 172. 16. 97. 8.
| -> Port RTCP RR = 32749, IPv4 : 172. 16. 97. 8.
| (316941:000071:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 5b
| IE:[18] CHANNEL (l=3) a8 83 8b -> T2 : No B channel
| (316941:000072:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 5b
| -> Port RTP = 32712, IPv4 : 10. 203. 0. 5.
| -> Port RTCP SR = 32713, IPv4 : 10. 203. 0. 5.
| -> Port RTCP RR = 32713, IPv4 : 10. 203. 0. 5.
| (316941:000074:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 5b
| (316942:000076:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 5b
| (316942:000077:04727) Concatenated-Physical-Event :
| (316943:000078:04727) Concatenated-Physical-Event :
| (316943:000079:04727) Concatenated-Physical-Event :
| (316944:000080:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 1c
| SENDING COMPLETE
| -> Port RTP = 32616, IPv4 : 172. 16. 97. 5.
| -> Port RTCP SR = 32617, IPv4 : 172. 16. 97. 5.
| -> Port RTCP RR = 32617, IPv4 : 172. 16. 97. 5.
| (316944:000082:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 1c
| (316944:000083:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 1c
| -> Port RTP = 32720, IPv4 : 10. 203. 0. 5.
| -> Port RTCP SR = 32721, IPv4 : 10. 203. 0. 5.
| -> Port RTCP RR = 32721, IPv4 : 10. 203. 0. 5.
| (316944:000085:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 1c
| (316944:000087:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 1c
| (316945:000089:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 1c
| (316947:000090:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 30 8c
| (316948:000091:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : b0 8c
| (316948:000092:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 30 8c
| (316953:000093:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 0 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 31 63
| (316953:000094:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| -> Port RTP = 32514, IPv4 : 10. 203. 1. 197.
| -> Port RTCP SR = 32515, IPv4 : 10. 203. 1. 197.
| -> Port RTCP RR = 32515, IPv4 : 10. 203. 1. 197.
| (316953:000096:04727) Concatenated-Physical-Event :
| long: 26 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : b1 63
| IE:[08] CAUSE (l=6) 80 90 00 00 00 00 -> [90] NORMAL CALL CLEARING
| (316953:000097:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 31 63
| (316964:000098:04727) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 0 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : b1 63
| (316964:000099:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : FACILITY [62] Call ref : 00 81
| (316999:000100:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 e0
| IE:[18] CHANNEL (l=3) a9 83 8a -> T2 : B channel 10 exclusive
| (317001:000102:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 e0
| (317008:000103:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 2b
| SENDING COMPLETE
| -> Port RTP = 32872, IPv4 : 172. 16. 101. 236.
| -> Port RTCP SR = 32873, IPv4 : 172. 16. 101. 236.
| -> Port RTCP RR = 32873, IPv4 : 172. 16. 101. 236.
| (317008:000105:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 2b
| IE:[18] CHANNEL (l=3) a8 83 95 -> T2 : No B channel
| (317008:000106:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 2b
| -> Port RTP = 32572, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32573, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32573, IPv4 : 10. 203. 0. 7.
| (317008:000108:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 2b
| (317009:000110:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 2b
| (317009:000111:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 30 99
| -> Port RTP = 32580, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32581, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32581, IPv4 : 10. 203. 0. 7.
| (317009:000113:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 30 99
| (317010:000114:04727) Concatenated-Physical-Event :
| (317010:000115:04727) Concatenated-Physical-Event :
| (317010:000116:04727) Concatenated-Physical-Event :
| (317010:000117:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : b0 99
| (317010:000118:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 30 99
| (317017:000119:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 3e
| SENDING COMPLETE
| IE:[04] BEARER_CAPABILITY (l=3) 90 90 a3
| -> Port RTP = 32604, IPv4 : 172. 16. 97. 20.
| -> Port RTCP SR = 32605, IPv4 : 172. 16. 97. 20.
| -> Port RTCP RR = 32605, IPv4 : 172. 16. 97. 20.
| (317017:000121:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 3e
| IE:[18] CHANNEL (l=3) a8 83 81 -> T2 : No B channel
| (317017:000122:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 3e
| -> Port RTP = 32588, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32589, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32589, IPv4 : 10. 203. 0. 7.
| (317017:000124:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 3e
| (317017:000126:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 3e
| (317018:000128:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 3e
| (317022:000129:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 e0
| (317043:000130:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| -> Port RTP = 32514, IPv4 : 10. 203. 2. 185.
| -> Port RTCP SR = 32515, IPv4 : 10. 203. 2. 185.
| -> Port RTCP RR = 32515, IPv4 : 10. 203. 2. 185.
| (317046:000132:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : FACILITY [62] Call ref : 00 3e
| (317059:000133:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 30 4b
| (317059:000134:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 30 4b
| -> Port RTP = 32596, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32597, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32597, IPv4 : 10. 203. 0. 7.
| (317060:000136:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : b0 4b
| (317060:000137:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 30 4b
| (317060:000138:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : REL COMP [5a] Call ref : b0 4b
| (317063:000139:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 02
| SENDING COMPLETE
| -> Port RTP = 32636, IPv4 : 172. 16. 101. 236.
| -> Port RTCP SR = 32637, IPv4 : 172. 16. 101. 236.
| -> Port RTCP RR = 32637, IPv4 : 172. 16. 101. 236.
| (317063:000141:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 02
| IE:[18] CHANNEL (l=3) a8 83 85 -> T2 : No B channel
| (317063:000142:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 02
| -> Port RTP = 32604, IPv4 : 10. 203. 0. 7.
| -> Port RTCP SR = 32605, IPv4 : 10. 203. 0. 7.
| -> Port RTCP RR = 32605, IPv4 : 10. 203. 0. 7.
| (317063:000144:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 02
| (317063:000146:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 02
| (317064:000148:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 02
| (317073:000149:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : SETUP [05] Call ref : 30 9b
| -> Port RTP = 32514, IPv4 : 10. 203. 2. 20.
| -> Port RTCP SR = 32515, IPv4 : 10. 203. 2. 20.
| -> Port RTCP RR = 32515, IPv4 : 10. 203. 2. 20.
| (317074:000151:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CALL PROC (02) Call ref : b0 9b
| (317077:000152:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : b0 9b
| -> Port RTP = 32888, IPv4 : 172. 16. 101. 236.
| -> Port RTCP SR = 32889, IPv4 : 172. 16. 101. 236.
| -> Port RTCP RR = 32889, IPv4 : 172. 16. 101. 236.
| (317077:000153:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT (07) Call ref : b0 9b
| (317077:000154:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT ACK (0f) Call ref : 30 9b
| (317077:000155:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 30 9b
| (317089:000157:04727) Concatenated-Physical-Event :
| long: 83 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 56
| SENDING COMPLETE
| IE:[6c] CALLING_NUMBER (l=9) -> 81 Num : 28570000
| -> Port RTP = 32514, IPv4 : 172. 18. 96. 132.
| -> Port RTCP SR = 32515, IPv4 : 172. 18. 96. 132.
| -> Port RTCP RR = 32515, IPv4 : 172. 18. 96. 132.
| (317089:000159:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 56
| IE:[18] CHANNEL (l=3) a8 83 96 -> T2 : No B channel
| (317089:000160:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 56
| -> Port RTP = 32632, IPv4 : 10. 203. 0. 6.
| -> Port RTCP SR = 32633, IPv4 : 10. 203. 0. 6.
| -> Port RTCP RR = 32633, IPv4 : 10. 203. 0. 6.
| (317089:000162:04500) 4500: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : FACILITY [62] Call ref : 80 56
| (317089:000164:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 80 56
| (317090:000166:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 00 56
| (317099:000167:04727) Concatenated-Physical-Event :
| long: 54 desti: 0 source: 0 cryst: 2 cpl: 11 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 2f 2d
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 81 -> T2 : B channel 1 preferred
| IE:[1e] PROGRESS_ID (l=2) 82 83
| IE:[6c] CALLING_NUMBER (l=11) -> 21 83 Num : 028427157
| IE:[70] CALLED_NUMBER (l=6) -> c1 Num : 75641
| (317099:000168:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 11 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : af 2d
| IE:[18] CHANNEL (l=3) a9 83 81 -> T2 : B channel 1 exclusive
| (317099:000169:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : ALERT (01) Call ref : af 2d
| (317100:000170:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 04 e0
| (317101:000171:04727) Concatenated-Physical-Event :
| long: 51 desti: 0 source: 0 cryst: 2 cpl: 15 us: 0 term: 0 type a5
| tei: 0 >>>> message received : FACILITY [62] Call ref : b0 9b
| -> Port RTP = 32514, IPv4 : 172. 16. 101. 110.
| -> Port RTCP SR = 32515, IPv4 : 172. 16. 101. 110.
| -> Port RTCP RR = 32515, IPv4 : 172. 16. 101. 110.
| (317101:000172:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| (317103:000174:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 84 e0
| (317103:000175:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 04 e0
| (317104:000176:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 11 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : af 2d
| (317106:000177:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT ACK (0f) Call ref : 2f 2d
| (317109:000178:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 31 5c
| (317111:000179:04727) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : b1 5c
| (317111:000180:04499) 4499: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 31 5c
ÿ^C
(9)mbtc_hyatt_a>
Thank you.
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
mtracer started ...
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
| SENDING COMPLETE
ÿ^C
(9)mbtc_hyatt_a>
Full trace - was about all messages for one call
In your case - calling user and TG - from one node or this is network call?
- jonnel_ponesto
Apologies for that.. it is actually the whole E1 trace which also include the Network call to other nodes. But the issue is from the same node using its own TG.
