manegement vlan on OAW-AP103
Also known as OmniAccess Instant AP
SFonoyet
Post by SFonoyet »
Hello
i have a 2 network with 7 ap in 2 differents cluster i there the possibility to add a vlan tag to the management ip?
this way i will merge both clusters in one central mgm point
Re: manegement vlan on OAW-AP103
not sure but you can try this setting: system - show advanced options - virtual controler vlan
Return to “OmniAccess Wireless Access Points”
