same number on two OXE node?
cricri
Post by cricri »
in a multi-oxe scenario.. what happens if you have the same number on two nodes? given that userid = oxe+directoryNumber, there'd be a collision?
rachlilas
Re: same number on two OXE node?
Post by rachlilas »
O2G only supports an homogeneous numbering.
galliou
Post by galliou »
However, the OXO number is not limited.
Not a big problem. Some misunderstanding with callback, call forwarding (f.e. you have two users 3000, when someone have forward to 3000 and called from node 1 or node 2) .
Return to “O2G”
