I am a newbie with the 6350 switch Alcatel
I watched an Alcatel video on youtube to setup the 6350
In this video there is a command
ip interface emp address 10.10.1.55 MASK 255.255.255.0
my question is : on the 6350 where is the EMP port ?? is it the RJ45 console ?
There are only 8 RJ45 ports + 2 fiber ports ?
The command has been successfully accepted, and I can show the interface EMP with the show command
Thanks for any help
Yves67
[Solved] EMPand prt ?
yves67
Re: EMPand prt ?
there is no EMP port - only at some R8-switches. Maybe the command is there, but without any function.
yves67
Re: EMPand prt ?
Thanks for your message
OK, no EMP port
to set up an IP address to the switch (for web, ssh, ftp access) should I do :
ip interface vlan_1 10.10.1.55 MASK 255.255.255.0
thanks for your help
yves67
OK, no EMP port
yves67
devnull
Re: EMPand prt ?
i think it should do.
normally you would add the "vlan command" as well (necessary if you have multiple vlans. The "vlan_1" is just a name.
ip interface vlan_1 10.10.1.55 MASK 255.255.255.0 vlan 1
See also http://www.latouche.info/admin/user_gui ... witch.html
