incorrect error when programming set supervision key
ssteiner
Post by ssteiner »
Just ran into this - I tried programming a set supervision key for the same station on two keys. Apparently that's not supported as mgr tells me the following when I try to do it.
Processing Failure x
x OBJECT -1: Key No.: There is redundancy on the key type
With O2G, I send
	"attributes": [{
		"name": "Type",
		"value": ["Station_Supervision"]
		"name": "Key_NOE_Mnemonic1",
		"value": ["labtest3"]
		"name": "Ringing_Mode",
		"value": ["Long_Ring"]
		"name": "Directory_Number",
		"value": ["1034"]
And the error I get back is this
	"httpStatus": "BAD_REQUEST",
	"code": 1006,
	"helpMessage": "Request parameters are not correct. Please fix the problem and resend the request.",
	"type": "BAD_PARAMETER",
	"innerMessage": "McdoException: problem=ProcessingFailure message=Processing Failure for Attribute id=Subscriber_Key error=819",
	"canRetry": true
Technically, that is correct, what I sent was not allowed, but practically, I think O2G should always return a useful error - in this case what mgr returns as this tells you something and you don't have to troubleshoot by attempting to do the same operation manually and see why it fails.
ssteiner
Re: incorrect error when programming set supervision key
Post by ssteiner »
Here's another example... this time the set where I wanted to program set supervision wasn't a multiline set.
In Mgr, this scenario gives you the following error
 x Processing Failure                             x
          x OBJECT -1: ATTRIBUTE 0: Set must be multi-line
The same on O2G gives you
	"code": 1006,
	"innerMessage": "McdoException: problem=ProcessingFailure message=Processing Failure for Attribute id=null error=902",
	"canRetry": true
the corresponding request
	"attributes": [{
		"name": "Type",
		"value": ["labteam2"]
		"value": ["1029"]
yblanchard
Post by yblanchard »
ok: whenever the pbx error message will contain an error code, O2G will add the error label (corresponding to the GEA one) if it is found in the error dictionary.
For example:
message=Processing Failure for Attribute id=Subscriber_Key error=819:there is redundancy on the key type"
ssteiner
Post by ssteiner »
is that new way or returning errors already part of the new build that was posted recently (14.0.000.027)?
yblanchard
not in 14.0.000.027: still need to wait for 0.28
Return to “O2G”
