Data & Voice VLAN on same port
mumer1166
Post by mumer1166 »
Dear Guys
I am using OS6860 in our environment. I want to use 2 vlans (Data Vlan 10 & Voice Vlan 20) on single access port just as we do in cisco.
Please guide me how can i achieve this goal.Please give step by step commands of this and also tell if & how to implement QoS for this case.
Re: Data & Voice VLAN on same port
vlan 10 enable name "vlan 10"
vlan 20 enable name "vlan 20"
vlan 10 ip 192.168.10.0 255.255.255.0
vlan 20 ip 192.168.20.0 255.255.255.0
vlan 10 port default 1/1
use the help and documentation. it is all explained. if you know Cisco, it will be easy.
TrX
Post by TrX »
vlan 10 name "vlan 10"
vlan 20 name "vlan 20"
vlan 10 members port x/x/x untagged
vlan 20 members port x/x/x tagged
surajkants
Post by surajkants »
I have same Issue, CASE, Data device not connected directly with port. Voice device connected directly, data device connected with voice device.
Switch--->ip_Phone_Voice_vlan10------->PC_Data_Vlan20 (Both need untagged traffic, in cisco using qos it done but in AOS release 8.x it's not working with tagged/untagged)
surajkants
vlan 40 name "User"
vlan 50 name "User_Voice" //Create two vlan 40 for user data and 50 for user voice
vlan 50 port default 1/5-20 // assign port 5 to 20 into default vlan 50 for user voice
vlan port mobile 1/5-20 //Enable mobile tag for port 5 to 20
vlan 40 ip 192.168.10.0 255.255.255.0 //Rule if frame received with subnet 192.168.10.0, vlan 40 assigned or work as secondary vlan
vlan 40 802.1q 1/24 //Making one port as trunk for uplink tag vlan 40
vlan 50 802.1q 1/24 //Making one port as trunk for uplink tag vlan 40
vlan 802.1q 1/24 frame type tagged //Rule for trunk port because 802.1q port not follow mobile port rule
ip interface vlan-50 address 192.168.50.1 255.255.255.0 vlan 50 //Assign Ip address on vlan
ip static-route 0.0.0.0/0 gateway 192.168.50.254 //Default Route
aaa authentication default local //enable http, telnet and ftp
lanpower start 1 //enable poe port
surajkants
Please follow below config steps to configure ip phones with pc connectivity.
Voice vlan ---- 20
PC vlan ------- 10
unp profile "DATA"
unp profile "VOICE"
unp profile "DATA" map vlan 10
unp profile "VOICE" map vlan 20
unp port-template datadefault direction both default-profile "DATA" classification trust-tag ap-mode admin-state enable
unp port 4/1/19-22 port-type bridge
unp port 4/1/19-22 port-template datadefault
unp classification-rule "VOICE"
unp classification-rule "VOICE" Profile1 "VOICE"
unp classification-rule "VOICE" mac-oui 00:80:9f(this should be actual mac of phone)
KV_Swami
Post by KV_Swami »
I am trying to use UNP for a port that will have a Crestron NVX352 Encoder/Decoder connected to it. The same LAN port on the device supports the Dante (Audio) Connection and the NVX (Video) Connection. There are separate MAC Addresses for each function. When i deploy the following then i am only getting the Dante Interface on the NVX Device to get an IP and pick up a UNP Profile. For the AV-Video Interface it says No SPB Resource. When i remove the UNP port settings and set it as a SAP Port it picks up the AV-Video Network.
Switch - OS6860E-P48 (8.6.289.R01)
unp profile "unp-AV-Dante-BLDF-F" mac-mobility
unp profile "unp-AV-Dante-BLDF-F" map service-type spb tag-value 168 isid 100168 bvlan 4000 multicast-mode tandem vlan-xlation
unp profile "unp-AV-Video-BLDF-F" mac-mobility
unp profile "unp-AV-Video-BLDF-F" map service-type spb tag-value 170 isid 100170 bvlan 4001 multicast-mode tandem vlan-xlation
unp port-template unp-wired-default direction both default-profile "unp-AV-Video-BLDF-F" classification trust-tag ap-mode admin-state enable
unp port-template unp-wired-default mac-authentication
unp port-template unp-wired-default mac-authentication pass-alternate "unp-AV-Dante-BLDF-F"
unp port 1/1/19-24 port-type access
unp port 1/1/19-24 port-template unp-wired-default
unp classification ip-address 10.21.168.0 mask 255.255.254.0 profile1 "unp-AV-Dante-BLDF-F"
unp classification ip-address 10.21.170.0 mask 255.255.254.0 profile1 "unp-AV-Video-BLDF-F"
unp classification mac-oui 00:1d:c1 profile1 "unp-AV-Dante-BLDF-F"
unp classification mac-oui 00:10:7F profile1 "unp-AV-Video-BLDF-F"
Is there a way to use UNP and provide (2) Services on one port?
KV_Swami
Post by KV_Swami »
Modifying the message as it actually did not work for me.
In my knowledge it should be possible. What is the reason for getting successfull the profile "unp-AV-Dante-BLDF-F"? Mac-classification, Mac-authentication or pass-alternate mac-auth? And where do you see the message: No SPB Resource?
please look into the following:
show unp user
show unp user status
show unp user xx:xx:xx:xx:xx:xx (for both your mac at the access port)
show unp user details (is the most interesting to find the reason)
if you do not use an radius-server for the mac-authentitcation then you should delete this point in the template.
no unp port-template unp-wired-default mac-authentication
KV_Swami
Post by KV_Swami »
Thank you Silvio. Will test this and revert back.
