Polycom SIP won't register on OXO R9.2
bcmir
Post by bcmir »
I am trying to connect the Polycom SIP conference phone to OXO R9.2, but cannot get it to register, although I have added 1 x IP User License?
I am not even sure that there is a VoIP board inside
The PowerCPU appears to be equipped with a VoIP16 boardm but Cabinet Topology picture below doesn't show it ??
This OXO is not using any SIP trunks (public or private).
Plus when I ordered the Ip User license in ACTIS, Iit didn't prompt me to order a VoIP board
The Wireshark trace says "SIP Error 501 Not Implemented"
Please see attachments for SIP traces and licence details:
dryhouse
Re: Polycom SIP won't register on OXO R9.2
Post by dryhouse »
i think you need licenses for SIP Phones.
Regards.
may the force be with you....
bcmir
Post by bcmir »
Thanks, I've ordered the Open SIP license..
fe80
Post by fe80 »
standard port for sip phones is 5059
rkraehen
Post by rkraehen »
Some points to compare with the attached document :idea:
bcmir
Post by bcmir »
Thanks... it was the missing license
Return to “H323 / IP / Pimphony”
