Problems to add one user ip touch 4068
atxu
Post by atxu »
Hi.
I have a virtual machine with version 7. I tried to register a 4068 ip touch and not let me. I get the following error:
lqError:qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x CANCEL to close this window x
x x
x Processing Failure x
x OBJECT -1: ATTRIBUTE 0: Lock 173/174/175/176/177 (Users): Protection Error x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
I have followed the process that shows slim on its website:
The smart way : renew the 30 days period by renaming /usr3/mao/software.mao to /usr3/mao/software.old, then reboot. Do it again the other way around.
Say us the process that i followed:
A. Rename / usr3/mao/software.mao / to usr3/mao/software.old
B.reboot
C. Delete / usr3/mao/software.mao
D. Rename / usr3/mao/software.old / to usr3/mao/software.mao
E. Reboot
Perhaps I did not understand the process that shows slim, someone I could elaborate further.
Thanks you.
:shock:
Re: Problems to add one user ip touch 4068
Well if you search on the forum that was my aport :)
Now the correct way is:
rename software.mao to software.old (mv not cp)
make sure there is no software.mao anymore (del software.mao)
now reboot
now re-rename (mv software.old software.mao and yes to replace warning message)
now reboot again and walla.
Return to “Other”
