OmniVista 4760 Installation always failed
alshebah
Post by alshebah »
I need to install OmniVista 4760
I try with Windows XP SP2 and SP3
I try with Windows 7 32Bit
I try with Windows Server 2003 STD and Ent.
I get same error
== 2019/05/07 22:16:07 ====================
Full log file: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\1\OmniVista4760_install.log
Installing version 5.1.04.00
== 2019/05/07 22:18:37 ====================
Action: Stop server SNMP
Action: Preparing removal of installation directory on error
Action: delete_omnivista_shortcut
Action: Remove shares in archive directory before install
== 2019/05/07 22:18:51 ====================
Action: Create missing directories
Action: Replace strings in directory url file
Action: Installation of httpd
Action: Installation of php
Action: Installation of Themes4
Action: Configuring httpd
Action: Override php.ini
Action: Configuring php
Action: copy patch SunONE in supportdir
Action: Creating SunONE install directory.
Action: Installation of directory server from D:\omni5.1\Setup\D52diu
Action: Delete directory "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\1\{C3CF0589-B127-4C15-A347-E0DCCBC74E87}\D52diuPatch"
Action: LDAPS Certificate generation and import
Action: Change LDAP directory server config in C:\4760\Netscape\server5\slapd-4760\config\dse.ldif
Action: Stop LDAP directory server
Action: Copy 4760 LDAP schemas in C:\4760\Netscape\server5slapd-4760\config\schema
Action: Start LDAP directory server
Action: Import of initial .ldif files
Action: Import of "sizelimit5.ldif install.ldif"
Action: Import of "add-plugins5.ldif"
Action: Applying fix for easy config.
Action: Backuping easy upgrade command.
Action: Backuping LDAP content for technical support.
Action: Replace strings scheduler LDIF files.
Action: Copy initial db files
Action: prepare rollback
Action: Installation of database from D:\omni5.1\Setup\ASA1001
Action: Waiting for ASA to install completely
Action: Installation of database patch from D:\omni5.1\Setup\ASA101Patch
Action: Installation of service ASANYs_nmc50
Action: Configuration of service ASANYs_nmc50
Action: Start database server
alex
Re: OmniVista 4760 Installation always failed
Post by alex »
4760 is supported only on:
-Windows XP® Professional SP3
-Windows 2003® Server Standard Edition SP2
-Windows 7® Professional 64 bits
-Windows 2008® R2 Server Standard Edition 64 bits
alshebah
Post by alshebah »
Thank you alex for your replay.
I try on all of these windows versions. VM and Physical machines. All failed.
I was try on fresh windows without any software or Antivirus, and I disabled firewall.
Return to “OmniVista 4760”
