NTP configured rejected
edd1180
Post by edd1180 »
Hi to all,
we currently have an Alcatel A9700E omniswitch. I have been trying to set the NTP server (Windows Server DC) but I have had no success what so ever; it remains as configured rejected.
I have tried the 'ntp server synchronize and unsynchronize commands' but to no use.
Is there anything else I can try to maybe have the switch reach the ntp server please?
Thank you for help.
his0825
Re: NTP configured rejected
Post by his0825 »
please check F/W or " show ip managed-interface "
and config ntp managed-interface
ex)
hostname> ip managed-interface Interface_name application ntp
junching
Post by junching »
Hi All,
I have the same problem, is there any improvement solution?
junching
do you have stratum 16 too? than you need "ntp server unsynchronized"
BR Silvio
junching
Post by junching »
we already have set "ntp server unsynchronized," but it doesn't work
