Recommendations for a IP65+ 8 port enclosure?
Scajaquada
Post by Scajaquada »
I am pulling network cables and analog phone cables to a remote location which is very wet and the terminations need to be protected from that moisture. Does anyone have an enclosure they have used for a similar situation, which they could recommend?
I am aware I could patch something together with a cheap IP65 enclosure with a 110 block epoxied to the inside of it, but I am looking for something that is a little bit more professional, and purpose built.
Thank you :)
Re: Recommendations for a IP65+ 8 port enclosure?
How about an aluminium cabinet ?
Return to “MAIN”
