Fuse of eZ-32 board
irfansahijee
Fuse of eZ-32 board
Post by irfansahijee »
[font=]Fuse of ez32 board[/font]
Can we install 5 A fuse in ez-32 board instead of 3A fuse
Re: Fuse of eZ-32 board
DO YOU WANT TO BURN IT ? WE SPOKE ABOUT CURRENT NOT VOLTAGE
No,
If you install a 5A fuse and actually 5A goes through the board, you'll fry the electronics on it, while your fuse will still accepts current to go through.
Not a good idea to ever increase fuse amperage when the manufacturer of any type of electronics tells you the max you can put.
from doc (z32 and e-z32):
F1: 3A-125V AC/DC quick-response fuse.
Caution:
Always replace with a fuse of the same type and ratings to avoid a fire hazard.
