How to use omnistack6224p in a lan
setare
Post by setare »
Dear all,
My boss gave me an omnistack6224p to establish a lan, i found its manual, i made its console port. I think it is new.
I connected 2 pc with proper ip, their led changed to green-red color, but ping request between them replayed “ destination host unreachable”. The ip range and computer name and firewall have not problem.
For solve the matter i have a basic question:
Whats the procedure to use a 6224p switch in a simple lan? Is it necessary to activate or enable the switch ports, some thing like that?
I will appreciate any advice.
setare
Re: How to use omnistack6224p in a lan
Post by setare »
Excuse me, the mention led color was green-yellow, as normal color.
jkohan
Post by jkohan »
maybe it was not brand new and had been configured with vlans. Did you factory reset it prior to trying ?. If not, do it an try again.
(I assume you double checked lan cables, and the like, did you ? ).
Javier
Return to “OmniStack LS 6200”
