Incoming calls are being rejected
aspire1245
Post by aspire1245 »
Outgoing calls are fine, going over SIP trunk, but incoming calls are being rejected. Ideas?
oldboy
Re: Incoming calls are being rejected
Post by oldboy »
Wow could you be any more vague ??
System Type?
Traces?
lots more but lets start with the basics!!!!
oldboy wrote: 19 Mar 2021 00:56 Wow could you be any more vague ??
System Type?
Traces?
:D
yazan1986
Post by yazan1986 »
If you can provide a trace would be very helpful .
If you have anonymous call it will be rjected
Return to “GENERAL”
