Transfer EXT/EXT - Displayed number
alexstreet3
Post by alexstreet3 »
Hi everyone,
I try to figure out how during a transfer ext/ext I can displayed on the transferred side the number of the first caller.
System: OXO R4
Pictorial explanation:
External User A calls an External User B. User B transfers the call to Ext user C.
I'd like the number of User A to be displayed on User C's phone.
Thank you in advance for your help.
Konstantinos.E
Re: Transfer EXT/EXT - Displayed number
Post by Konstantinos.E »
does your provider supports this function?
Alca_holic
fery_s
Post by fery_s »
that must be support by your provider too, some of provider support it just for main number (DDI 0)
Return to “Configuration”
