I am new with Alcatel switches and I need some help to configure NAT for the new network I have created. The switchs are Alcatel OminiSwitch 6350 models.
The switch has VLAN 1 interface with 192.168.0.100 IP and 192.168.0.1 as GW:
ip interface vlan-1 address 192.168.0.100/24 vlan 1
ip static-route 0.0.0.0 mask 0.0.0.0 gateway 192.168.0.1Code: Select all
vlan 20 name "GUEST"
ip interface vlan-20 address 192.168.20.1/24 vlan 20
vlan 20 port default 1/13-14Code: Select all
policy condition GUEST-NETWORK source ip 192.168.20.0 mask 255.255.255.0
policy action NAT-IP source rewrite ip 192.168.0.100
policy rule NAT-GUEST condition GUEST-NETWORK action NAT-IP
qos applyCould someone help to configure NAT for this switches?
I will really appreciate your help.
Best regards.
