BGP-VPLS SDP failing to come up
Ynysmeudwy99
Post by Ynysmeudwy99 »
Hi all,
I'm trying to set up a basic BGP-VPLS config in the lab and I cant get the SDP to come up within the VPLS itself. LDP tunnel is up
sdp:12:4294967289 S(************) BgpVpls 0 9166 Up Down
Flag indicates this:
Flags : PWPeerFaultStatusBits
I may well be missing a simple step here but any help would be great.
paramount
Re: BGP-VPLS SDP failing to come up
Post by paramount »
Please can you share configs from both ends?
Cheers
Paramount
Ynysmeudwy99
Hi Paramount,
Configs attached.
BGP comes up and routes are exchanged.
Martin
paramount
Post by paramount »
Apologies for delay. I just tested your configs, and had the same as you. As soon as I added a SAP that was in the up state to both ends VPLs, then the SDP binding came up. The status is telling you that the remote end is down. Ie there is no egress point.
If I just do a shutdown of the SAP, then the remote end shows the SDP binding as down.
Cheers
Paramount
Ynysmeudwy99
Hi Paramount,
No problem my apologies as well for the late reply.
Thanks for tht. I'll try that again in the lab and let you know how I get on.
Martin
paramount
Post by paramount »
Croeso Martin.
Let me know how you get on
Paramount.
Ynysmeudwy99
Diolch yn Fawr Paramount :)
Dragon Blood by any chance?
paramount
Post by paramount »
Apologies I had no notification of this at the time.
Yes - picked up on your username!! I'm West Wales based :-)
Ynysmeudwy99
Hey no worries same hear.
I’m from West Wales originally but just outside Reading now.
Return to “7750 SR”
