Console port/usb console
jcurley
Post by jcurley »
I recently acquired a 6450-48p as EoL surplus from my work but I do not have the rj45-db9 adapter that would have initially come with the switch. I have been research all morning but have yet to come across any concrete evidence of what adapters will work (just that standard adapters will not) I was wondering if anyone has any guides on either connecting to console via the USB port on the switch or what model of adapter will work for this switch.
Re: Console port/usb console
USB of the switch is not possible. You need the RJ45-Adapter. This is different to cisco adapters. But you will find in the forum here some pictures etc. - it is the same adapter for (nearly) all OmniSwitches and the PBX.
Return to “OmniSwitch 6450”
