IP address on VLAN
EmptySet
IP address on VLAN
Post by EmptySet »
Hello everyone,
I have had to power on an old OS6850 for emergency use and I'm having an issue; this particular switch seems to have an IP assigned to VLAN 1 that I can't seem to remove. I apologize, I'm not fluent in Alcatel syntax so this may be a very easy solution.
show configuration snapshot
Returns:
vlan 1 enable name "vlan 1"
vlan 1 ip 172.16.2.1 255.255.0.0
This makes me think it's a layer 3 VLAN but it doesn't have an interface under
show ip interface
And because it's VLAN 1, I can't remove the VLAN.
How can I remove the IP address from VLAN 1?
Thanks in advance.
Re: IP address on VLAN
you have configured a vlan rule. Delete it and configure the ip interface with this comand:
ip interface IF-1 address 172.16.2.1/16 vlan 1
EmptySet
Post by EmptySet »
Thank you for the reply. You are correct, there is a VLAN rule.
show vlan rules
Shows an ip-net rule. However, when I try and remove the IP network rule :
VLAN 1 no ip 172.16.2.1
I get an error: ERROR:GROUP MOBILITY - RULE NOT PRESENT
Is there a different syntax to remove the rule?
Thanks.
try the rule with mask - or the no at the start of the line.
EmptySet
Post by EmptySet »
Thank you… adding the mask to it did remove the rule.
Appreciate the help!
