sfp connection between switches
ramyrez
Post by ramyrez »
I have issues when i try to connect between two switch OS6860-24 and OS6465-P28 using sfp port , the problem is there is no connection between them when i try to ping other switch ,is there are any solution .
Note :
  • When i tried with other switch OS6860-24 and OS6860-24 or OS6860-24 and OS6465-P12 is work perfect
  • Also for OS6465-P28 with switch like him also it work.
  • But when i try OS6465-P28 with other switch it dosn't work.
Thanks for help.
Re: sfp connection between switches
try with disable autonegotiation, speed setting to 1G etc. (both sites)
After changes - port down/up ..... try all the different variants. Hopefull you will find setting that are working.
There are some issues depending on the used switches - this should be solved with ne next release.
Return to “OmniSwitch 6465”
