LoLA
steg81_DUP
LoLA
Post by steg81_DUP »
When I try to LoLa an OXO "any OXO"
It takes ages for the BOOTP to complete, per line it takes around 5 mins = 3xx-seconds.
Has anyone come across this before, or even know a fix. I have looked at the help file in LoLa and all is generic in the REGEDIT department.
aflores
Re: LoLA
Post by aflores »
Hello. I have many trouble with lola in the past.
Now, when I use lola, I also use a swich in wich one only are conected the oxo and the pc (anything else).
Since I do that, all my troubles with lola desappear.
The boot takes about 1 minute to appear.
Also, i recomemd you to disable the windows firewall, or any other one, and the antivirus too.
AFLORES
Return to “MAIN”
