ip phone "no tftp response"
ycama
Post by ycama »
hello,
first, Sorry about my english.
My probleme is all ip-phone display "no tftp response".
I checked the traces with tcpdump and I noticed that the oxe does not send the binaries to the ip post, and i checked with the command netstat -na | grep :69 and it return empty.
how can I open all the necessary ports for proper functioning, or how can I return default setting
Re: ip phone "no tftp response"
We talk about new installation or before everething was ok? but now broken?
ycama
Post by ycama »
New installation
oldboy
Post by oldboy »
Ok so a couple of questions.
Do you have any users created as IP??
Have you tried Static, IP and TFTP to the OXE?
lanpbxbuild ???
ycama
Post by ycama »
Yes, i have a users created as ip, and the adress are statics,
Evry thing is correct
What about lanpbxbuild? TFTP address declared in IP phone? VLAN used or no? CPU and IP phone - in one VLAN or not?
oldboy
Post by oldboy »
oldboy wrote: 28 Feb 2022 22:43 Ok so a couple of questions.
lanpbxbuild ???
lanpbxbuild ??? so you didnt answer this?
TFTP address in the Phone?
ycama
Post by ycama »
i checked evry thing is correct,
in tcpdump the phone ask for binary file but the oxe doesn't send it
no other ip phone runing ?
did you check the phone binaries existance in the oxe ?
ycama
Post by ycama »
No ip phone is runing,
The binaries existe in the oxe
Return to “MAIN”
