i've got a problem with old alcatel switch.
OS6250 2*24 ports
show microcode
Package Release Size Description
KFbase.img 6.6.3.451.R01 15805347 Alcatel-Lucent Base Software
KFos.img 6.6.3.451.R01 2513959 Alcatel-Lucent OS
KFeni.img 6.6.3.451.R01 5114273 Alcatel-Lucent NI software
KFsecu.img 6.6.3.451.R01 597711 Alcatel-Lucent Security Management
CONFIGURATION STATUS
Running CMM : PRIMARY,
CMM Mode : DUAL CMMs,
Current CMM Slot : 1,
Running configuration : CERTIFIED,
Certify/Restore Status : CERTIFY NEEDED
SYNCHRONIZATION STATUS
Flash Between CMMs : SYNCHRONIZED,
Running Configuration : NOT SYNCHRONIZED,
Stacks Reload On Takeover: ALL NIs (CMM Only Config OUT-OF-SYNC) Code: Select all
File configuration: none scheduled
Error file limit: 1
Running configuration and saved configuration are different"Write memory is not permitted when switch is running in certified mode"
what would be the method to save the configuration correctly ?
Thanks for your help
Pascal
