we have 20 access points on the first 20 ports of the switch.
The device was working fine for a few weeks (new installation)
Now, all access points are off, they do not receive power - no LEd.
I visited the site and I see that all PoE ports are off, no LED on the switch. The rest Data ports are working fine, I am able to connect on the switch normally.
I rebooted the switch and all PoE ports came back again.
After 3 days same thing, all poe ports are down.
below I see this: please explain
-> show lanpower slot 1/1
Port Maximum(mW) Actual Used(mW) Status Priority On/Off Class Type
1 30000 6700 Powered On High ON *
2 30000 6800 Powered On Low ON *
3 30000 6500 Powered On Low ON *
4 30000 6700 Powered On Low ON *
5 30000 7000 Powered On Low ON *
6 30000 6800 Powered On Low ON *
7 30000 6600 Powered On Low ON *
8 30000 6900 Powered On Low ON *
9 30000 9100 Powered On Low ON *
10 30000 6800 Powered On Low ON *
11 30000 9400 Powered On Low ON *
12 30000 6600 Powered On Low ON *
13 30000 7200 Powered On Low ON *
14 30000 9100 Powered On Low ON *
15 30000 7500 Powered On Low ON *
16 30000 6800 Powered On Low ON *
17 30000 9600 Powered On Low ON *
18 30000 6800 Powered On Low ON *
19 30000 6700 Powered On Low ON *
20 30000 9200 Powered On Low ON *
21 30000 6800 Powered On Low ON *
22 30000 0 Searching Low ON *
23 30000 4000 Powered On Low ON *
24 30000 6700 Powered On Low ON *
25 30000 0 Searching Low ON *
26 30000 0 Searching Low ON *
27 30000 0 Searching Low ON *
28 30000 0 Searching Low ON *
29 30000 0 Searching Low ON *
30 30000 0 Searching Low ON *
31 30000 0 Searching Low ON *
32 30000 7200 Powered On Low ON *
33 30000 0 Searching Low ON *
34 30000 0 Searching Low ON *
35 30000 0 Searching Low ON *
36 30000 0 Searching Low ON *
37 30000 2900 Powered On Low ON *
38 30000 0 Searching Low ON *
39 30000 0 Searching Low ON *
40 30000 0 Searching Low ON *
41 30000 0 Searching Low ON *
42 30000 0 Searching Low ON *
43 30000 0 Searching Low ON *
44 30000 0 Searching Low ON *
45 30000 0 Searching Low ON *
46 30000 0 Searching Low ON *
47 30000 0 Searching Low ON *
48 30000 0 Searching Low ON *
ChassisId 1 Slot 1 Max Watts 740
-900 Watts Actual Power Consumed
1640 Watts Actual Power Budget Remaining
740 Watts Total Power Budget Available
1 Power Supply Available
'*' appending port maxpower indicates 4pair port operating in 2pair mode
-> show running-directory
CONFIGURATION STATUS
Running CMM : MASTER-PRIMARY,
CMM Mode : VIRTUAL-CHASSIS MONO CMM,
Current CMM Slot : CHASSIS-1 A,
Running configuration : CERTIFIED,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Running Configuration : SYNCHRONIZED
-> show configuration snapshot
! Chassis:
system name "SWITCH_1_BASEMENT_1"
system contact "xxx"
system location "BASEMENT 1 U15"
! Configuration:
configuration error-file-limit 2
! Capability Manager:
! Virtual Flow Control:
! Interface:
! Port_Manager:
! Link Aggregate:
! VLAN:
vlan 1-4 admin-state enable
vlan 2 name "KNX"
vlan 3 name "VOIP"
vlan 4 name "GUEST_WIFI"
vlan 2 members port 1/1/37-46 untagged
vlan 3 members port 1/1/23-30 untagged
vlan 2 members port 1/1/36 tagged
vlan 2 members port 1/1/47-48 tagged
vlan 2 members port 1/1/53-54 tagged
vlan 3 members port 1/1/1-22 tagged
vlan 3 members port 1/1/47 tagged
vlan 3 members port 1/1/53-54 tagged
vlan 4 members port 1/1/1-3 tagged
vlan 4 members port 1/1/5-18 tagged
vlan 4 members port 1/1/20-21 tagged
vlan 4 members port 1/1/31 tagged
! Spanning Tree:
spantree vlan 1 admin-state enable
spantree vlan 2 admin-state enable
spantree vlan 3 admin-state enable
spantree vlan 4 admin-state enable
! DA-UNP:
! Bridging:
! Port Mirroring:
! IP:
ip service snmp admin-state disable
ip interface "management" address 192.168.1.3 mask 255.255.255.0 vlan 1 ifindex 1
ip interface "vlan_1" address 172.16.0.2 mask 255.255.252.0 vlan 1 ifindex 2
! IPMS:
! AAA:
aaa authentication telnet "local"
aaa authentication http "local"
! NTP:
ntp server pool.ntp.org
! QOS:
! Policy Manager:
! LLDP:
! Session Manager:
! Web:
! Trap Manager:
! Health Monitor:
! System Service:
ip name-server 8.8.8.8 8.8.4.4
ip domain-lookup
! SNMP:
snmp security no-security
snmp community-map hash-key 14be9558b08f30d389763c42542327a6 user "public" enable
! IP Route Manager:
ip static-route 0.0.0.0/0 gateway 172.16.0.1 metric 1
! LAN Power:
lanpower port 1/1/1 priority high
lanpower slot 1/1 service start
! DHCP Snooping:
! OVC:
! IP DHCP RELAY:
! MGMT AGENT:
PS: After reboot, the poe metrics are normal:
s-> show lanpower slot 1/1
1 30000 6400 Powered On High ON *
2 30000 6400 Powered On Low ON *
4 30000 6600 Powered On Low ON *
5 30000 6700 Powered On Low ON *
6 30000 6500 Powered On Low ON *
7 30000 6500 Powered On Low ON *
8 30000 6600 Powered On Low ON *
9 30000 6500 Powered On Low ON *
10 30000 6900 Powered On Low ON *
11 30000 9100 Powered On Low ON *
12 30000 6500 Powered On Low ON *
13 30000 7000 Powered On Low ON *
14 30000 6600 Powered On Low ON *
15 30000 6500 Powered On Low ON *
16 30000 6400 Powered On Low ON *
17 30000 6500 Powered On Low ON *
18 30000 6300 Powered On Low ON *
19 30000 6500 Powered On Low ON *
20 30000 7100 Powered On Low ON *
21 30000 6100 Powered On Low ON *
24 30000 6400 Powered On Low ON *
26 30000 6600 Powered On Low ON *
32 30000 0 Searching Low ON *
37 30000 3000 Powered On Low ON *
160 Watts Actual Power Consumed
580 Watts Actual Power Budget Remaining
all PoE devices on ports are down!
Re: all PoE devices on ports are down!
hi
any update on this?
i have a second switch with exactly the same behaviour
please advice
thanks.
any update on this?
please advice
thanks.
- Gleylancer
Check the swlog to find out what happened at the time of power loss. From looking at the "show lanpower", it seems like everything is working fine, before and after...
Hi.
I opened a support ticket and this is the solution:
This is a software known issue and it is fixed in the 5.1R02, which is available for download in the portal.
Thanks.
Thanks.
Ηi,
I have the same problem.
I am using the latest version (OS2260-P48 5.1.80.R01 GA) but the problem remains.
I had the same problem in the past but everything was resolved with a simple upgrade.
Any ideas?
Any ideas?
5.1R02
slaskaridis wrote: ↑07 Sep 2022 03:28 Hi.
Thanks.
