Hi Guys,
i recently installed 2 new OXOs CPU-3m - R610_007.002 (CE and L) and on each one i got the same situation:
- Flashed newest Release with lola
- programmed the users
- when i try to change the operator password on the Advanced OR 4039 device i get the following error "Funktion unzul." (german).
A warm reset didn't help !
I didn't try to do a cold reset because the machines had to run immidiately.
Yesterday i got an idea: Installed OMC in EASY-Mode and tried to change the operator password. This was the only way to change it. Now everything is running without any problems.
Did someone had the same error ? Can someone reproduce it ? Is it a new bug ?
Can't change operator password
alcatelspares
Re: Can't change operator password
I thought yoy could only change the installer PW
Avi1
starting PM5/OMC in Easy Mode you can change the operator password.
- Krusty65
Just tried it on a cpu-2 running R610/007.002 (Australian) with a 4068 & a 4035 without any issues, it may be a bug in the country version that you use.
Hi, I have experienced the same problem, following an upgrade. I found the only cure was to cold reset and re-program the database manually.
ltef
I created a SR on the BPWS, and get the answer that this is a known bug, and will be fixed in R610/011.001. (Not yet released)
Alex_Brazil
Hi Avi1Avi1 wrote:starting PM5/OMC in Easy Mode you can change the operator password.
How can I get in Easy Mode on OMC 6.1?
Avi1
Alex_Brazil wrote:Hi Avi1Avi1 wrote:starting PM5/OMC in Easy Mode you can change the operator password.
When you have installed only ONE Version of PM5 / OMC on your pc, you have to rename the "Expert.dll" and the "Easyplus.dll" in your OMC / BIN / Directory.
When you have installed more versions or older versions, then you have to rename ALL Expert.dll and Easyplus.dll files on your PC !!!!
Just rename them to some other names. I prefer "Easyplus.dll.bak" and "Expert.dll.bak"
et
Why so difficult? In PM5/OMC in initial state (when you don't connected to OXO) go "View/ Easy View". After that - connect to your system.
