UPGRADE SWITCH VIA OV2500
zepeki
Post by zepeki »
I create this topic because I have to make a campaign of update of the switches (approximately 120). Every night I perform a scheduled update at 3:00 am of five switches. Only half of them do not update. Here is the error message that comes up in the ov2500 "object.taskexecutor.profile.device.message.timeout.progress"
Do you have any idea where the problem comes from?
Thanks in advance for your answers,
Sincerely,
Zepeki
Re: UPGRADE SWITCH VIA OV2500
maybe the session timeout for ssh (cli) is to short to load all the files into the switch.
Are you able with this switches to do a "normal" update via OV?
BR Silvio
