help plz
electreng
help plz
Post by electreng »
hi all
any body can help me plz?
i have alcatel 4400 controlled by IP connection
please inform me how can i check the log files (the caller,destination, duration, and the time of the call) :( [/b]
chris.raper
Re: help plz
Post by chris.raper »
Hopefully for you, your system is storing accounting tickets.
If so, you can telnet to the system and do the following:
(198)node98> cd /usr4/account/
(198)node98> ll
total 184
-rw-r--r--    1 mtcl     tel            13 Dec  5 09:49 ACCOUNT.LIS
-rw-r--r--    1 mtcl     tel        112320 Jul 20 11:00 ASCFILES.log
-rw-r--r--    1 mtcl     tel             0 Dec  5 09:49 BUFFER.dat
-rw-r--r--    1 mtcl     tel             0 May 12  2006 EXTACCTR.log
-rw-r--r--    1 mtcl     tel             0 May 12  2006 FRAC.dat
-rw-r--r--    1 mtcl     tel             0 May 12  2006 FRCC.dat
-rw-r--r--    1 mtcl     tel             0 May 12  2006 FRDA.dat
-rw-r--r--    1 mtcl     tel             0 May 12  2006 FREPORT.log
-rw-r--r--    1 mtcl     tel             0 May 12  2006 FRTG.dat
-rw-r--r--    1 mtcl     tel            24 Dec  5 09:49 IP.LIS
-rw-r--r--    1 mtcl     tel            64 Jul 20 11:00 IP.log
-rw-r--r--    1 mtcl     tel           493 Jul 20 10:14 IPASSXP.DAT
-rw-r--r--    1 mtcl     tel           953 Jul 20 11:00 IPASSXQ.DAT
-rw-r--r--    1 mtcl     tel            39 Dec  5 09:49 MAO.LIS
-rw-r--r--    1 mtcl     tel            96 Nov 12 15:14 MAO.log
-rw-r--r--    1 mtcl     tel           514 Nov 12 12:04 MAOASWZP.DAT
-rw-r--r--    1 mtcl     tel           456 Nov 12 13:01 MAOASWZQ.DAT
-rw-r--r--    1 mtcl     tel          1426 Nov 12 15:14 MAOASWZR.DAT
-rw-rw-r--    1 mtcl     tel           366 Nov 12 10:11 TABJUSTIFM.dat
-rw-rw-r--    1 mtcl     tel          1024 Nov 12 10:11 TABJUSTIFM.idx
[b]-rw-r--r--    1 mtcl     tel           967 Jul 20 11:00 TAXASSXK.DAT[/b]
-rw-rw-r--    1 mtcl     tel             7 May 12  2006 VERSION.dat
-rw-r--r--    1 mtcl     tel             0 May 12  2006 freport.txt
-rw-r--r--    1 mtcl     tel         11360 Dec  5 09:49 stack.trc
(198)node98> accview -tf TAXASSXK.DAT |more
Look for the applicable accounting ticket (TAXA.....) based on the time it was created (written by the system)
Using the accview -tf command will view the ticket for you ( '|more will view page by page)
Good luck :D
intersol
Re: help plz
Post by intersol »
The repetitive process of getting, processing and importing the logs will take you very much time... but it's your time not mine ;)
Alternatively you can use a call accounting software that cand talk with Alcatel via IP, there are not so many.
It seamns that you can use the free version of PbxTools PhoneJournal - Call Accouting. If I remember well it will show you only the last 100 calls but i will not expire and this is quite cool.
chris.raper
Re: help plz
Correct - sorry I was thinking you were only trying to track one particular call.
For real time accounting you can use either Serial or TCP.
You can also use Omnivista if you have the accounting module for reports
sqls
Re: help plz
Post by sqls »
I'm currently writing a php script that will connect to, download, and store the call accounting information into a DB. I've got the call accounting files figured out - being how they are just compressed text files. But the IP log files and MAO log files I'm unsure about. Is there any documentation explaining the format of these files? I believe the IP files represent extension to extension calls but the files seem to be in a binary format. The MAO files are plain text but I'm not sure what they are suppose to represent. If I can get this information and get it all working. I'll be happy to publish a copy of the php script for everyone.
Thanks.
chris.raper
Re: help plz
The mao files are a log of changes made to the database (aka. mao)
they can be viewed on the oxe from /usr4/account using "maoview -tf MAOXXXX.DAT" where MAOXXXX is the mao file name.
As for the IP Tickets, check out http://www.ipview-analyzer.de/ which is I believe written by mr_sven - he should be able to assist in ipview information.
You can also view the IP tickets by ipview -f IPXXXX.DAT (similar to maoview)
sqls
Re: help plz
Post by sqls »
chris.raper wrote:The mao files are a log of changes made to the database (aka. mao)
Thanks for the information on the MAO files. I've got the IP and TA files decoded already and have a script in place that pulls them from the pbx and adds the records to a MySQL db. I also have it where it will poll all records from both our main and standby pbx. It's a really fantastic thing for us ( my company ) because it's letting us bypass the OnniVista software we have. Which we've found to be very limited in our environment. I need to clean up the code a lot and test it. But I'd be happy to post it once done if anyone else is interested.
Return to “MAIN”
