Hello
can I have the method for how to configure the SIP extension call grouping
I tried the classic method on the OXE!! it does not work
could you help me,
thank you so much
parallel grouping of SIP extension unsuccessful !!!
Re: parallel grouping of SIP extension unsuccessful !!!
Classic - hunt group not works?
Contador12
and for 8088 périferique sip is there a way to group them.
Frank
Hunting group, where I can configure it
Thanks in advance
Frank
Thanks in advance
- frank
Group / Hunt Group.
It's all in the doc my friends.
ahqswitchroom4466
you should go with tendam and Attached MultiDevice
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
