call forwarding on busy or after a few rings
DjeSan
Post by DjeSan »
Hello to you
I would like to know if you can help me. I am very new to Alcatel and I would like to know if it is possible to forward a call to my boss's secretary after 4 rings or if he doesn't pick up, he just asked me this morning and I never thought about it before.
I have a 4400 R10.1 with a Cpu: c7s2
Re: call forwarding on busy or after a few rings
Depends what your need exactly.
You can manage Manager-Assistant (Boss-Secretary) feature. You van use "forward on no answer" feature.
You can use hunt group (boss-secretary) with sequentuional search.
Manager -assistant and programmed key : set supervision with ring and call pickup
oldboy
Post by oldboy »
Just use associate and configure timer 4 for the length of time you want it to ring
Return to “Groups”
