Someone help me.
I have a Central BABX OmniPCX Enterprise (Release R9.0) but the problem is with External calls, but this happens to me with only one local operator (Mobile phone networks) which starts with 048-xxx-xxx when I want to call it with this prefix that starts first digit 048 error number occurs.
With the same operator (Mobile phone networks) which has a prefix that starts with other digits with 049 or 046, I have no problem, I also have no problems with international ones.
To make an external call, dial the number 0
External Calls wrong number (only one local operator Mobile phone networks)
Re: External Calls wrong number (only one local operator Mobile phone networks)
How is the number discriminator setup under the External numbering plan, sounds like they have broken out 049 and 046 and not added 048, not to sure why they wouldnt just have 04xxxxx
Show t3 (or SIP) trace for good and bad calls.
Error occurs - what do you mean? PBX not dial number or not allow to dial. Extternal operator reject (with some reason)?
Now it is working thank you very much for your help.
thank you very much ,
it was exactly what you mentioned, we had not added the number starting with 048 to the number discriminator list and now it is working.
