I bought a new switch alcatel omniswitch 6860N-P24M and I can't access it through the console provided. The console is micros USB to RJ-45.
Any idea how can I access it.
https://www.thetelecomshop.com/au/alcat ... witch-6860
Thank you
Alcatel Omniswitch 6860N-P24M
- Gleylancer
Re: Alcatel Omniswitch 6860N-P24M
You did not say what else you're using to access the Serial Port. Windows? COM/RS232 Adapter?
Try it with 115.200 Baud and a Cisco Adapter (this is the same like for ALE Wlan-Controller or other vendors).
BR Silvio
BR Silvio
The below is the way you can access the switch with cable connectivity:
micros USB to RJ-45 <-> Straight UTP -> DB9 connector of ALE <-> USB to Serial console cable.
Use baud rate 115200.
Also download the drivers usb to serial, if you don't have.
https://www.prolific.com.tw/US/ShowProd ... 25&pcid=41
