Install R100.1 in vmware or virtualbox
- frank
Re: Install R100.1 in vmware or virtualbox
You did not install the full distribution, the installation got interrupted, or you did not read the documentation specially around virtual machine setup recommendations.
If you check the pc installer server traces you probably found that the installation was interrupted somewhere, i remember getting same issue when installing f5401 via bios. i got kernel instead of cli prompt. i formate the hdd and reinstall
I attached the screenshot and log, could you help to give some comment?
what is the version of PC Installer u using ?
i see a question about activating server (oxe) security so llinux is good ?!
can u type any command ike netadmin
In the syslog it is complaining re dhcp lease no free addresses which is strange, the linux looks fine.
Have you tried just the base instead of the full version ?
Try 5.6
